Gotek burn hot arm chip
hamastermaniac77
Post by hamastermaniac77 »
hi
recently i have found an gotek hxc , in atari stf dead
gotek turn on, but lcd stay on 000
i opened and arm chip is verry hot
can you help me ?
Re: Gotek burn hot arm chip
hamastermaniac77 wrote: Sun Feb 18, 2018 9:19 pm hi
can you help me ?
remove the gotek from the ST.
Check the +5V voltage in the ST and check the 3.3V LDO regulator.
hamastermaniac77
i only plug in 5v
arm is very hot
Have you the necessary stuff to diagnose the problem ? (a voltmeter).
If not i recommend you to get another gotek and avoid to plug it into this ST.
hamastermaniac77
yes at voltmeter i have LT1117 4.8V in exit
ARM is really hot and now nothing on lcd he died
i go to bought another gotek
thx
tzok
Post by tzok »
Take care that pin 1 of the ribbon cable goes to the pin 1 on Gotek... original STfm floppy drive had this connector upside down, so you either have to mount Gotek upside down or twist the ribbon cable. If you plug the cable as it was in original FDD, you are shorting all I/O pins to GND, what may damage the STM chip. Look at the color stripe on a ribbon cable, and not at a notch on the plug.
