re coco 2 and hxc floppy emulator
jdavis6809
Post by jdavis6809 »
hello,
have two coco 2's (64k) with tandy floppy interfaces (normal dos)
I know the computers, floppy interfaces and cables are fine, tested with 3.5" floppy drives.
when interfacing with hxc floppy interface (rev c latest firmware)
I get I/o error (tries to read 0 to 17 tracks a few times then stops)
has anyone tried to use this set up ?
read a pervious post that highlighted the same problem but with no solution
regards john davis
Re: re coco 2 and hxc floppy emulator
which images are you trying ?
jdavis6809
hello jeff,
trs-80 tosec v 2011-01-01-cm
work with emulator ok (xroar)
regards
john davis
jdavis6809 wrote: Wed Jan 17, 2018 12:38 pm hello jeff,
regards
john davis
can you send me one of these image to "hxc2001 (at) hxc2001.com" ?
