Opus Discovery hxc support
caver99
Post by caver99 »
Would it be possible to add support for the 178k and 800k opd images for floppys to the gotek?
Re: Opus Discovery hxc support
caver99 wrote: Thu Dec 28, 2017 10:20 pm Would it be possible to add support for the 178k and 800k opd images for floppys to the gotek?
yes sure. is there some images to test ?
(btw probably already supported with the native HxC Floppy Emulator file format : HFE ;) )
vperlik
Post by vperlik »
I wanted to load an image file from Opus Discovery (with the extension .opd) into HxCFloppyEmulator and I got the message "Load Error". According to the documentation, it should know this format, it is a similar raw format, such as TRD, MGT, etc. I can load it via the Load RAW image function, but I have to manually enter the parameters, i.e. the number of tracks, sectors, sector size, etc. It would be nice if it loaded this type straight away.
vperlik wrote: Mon Oct 30, 2023 4:41 pm Hi,
it is defined in the predefined formats.
