Emax Config Autoboot files etc...
Kna
Post by Kna »
Hi
Im trying to run my *.hfe files from my newly installed Lothartek Rev F, but I get a "Non Fat SD" -error message when trying to navigate the SD in the floppy emulator.
I tried to Make A Config-file as instructed here: https://hxc2001.com/floppy/forum/viewtopi ... =15&t=1412
(In the Floppy Emulator Software)
But I dont understand where I can find the Autoboot -file? Im supposed to have such a file on the card, in addition to the config-file,
to be able to navigate between hfe-disks, right?
Re: Emax Config Autoboot files etc...
Kna wrote: Thu Dec 28, 2017 4:57 am Hi
Have you formatted the SDcard in FAT (32 or whatever) ?
Kna
Post by Kna »
I have formatted the SD-card in FAT32 (on a Win7 machine)
Am I supposed to have an autobot-file on the card?
No, just some file images and the default config file.
You can found some images for emax into this archive :
Kna
Post by Kna »
I tried to format to different SD-cards with both FAT and FAT32, just getting "Non Fat Card" message in emulator drive when inserted.
Does the emulator drive support all kinds of SD-cards?
Kna
Post by Kna »
The cards I use might be SD/MMC cards... maybe I should switch to SDHC?
Kna wrote: Thu Dec 28, 2017 10:55 pm The cards I use might be SD/MMC cards... maybe I should switch to SDHC?
The emulator should take any sdcard. But few tests have been done on the old MMC cards. I recommend you SD / SDHC cards.
(A btw a fast one for the Emax : Class 10 Sandisk Extreme)
EDIT : "Non Fat card" means that you haven't formatted your SDCard in FAT. Please format it in FAT32 !
Kna
Post by Kna »
Okay, I will have to wait for the SDHC-cards to arrive. I did format the MMCs in FAT32, didn't work.
Thank you for the fast replies Jeff, you are a beacon of hope. :)
Kna
Post by Kna »
Hi again.
The new SDHC cards has arrived.
I have formatted it with FAT32 and put the HXCSDFE.CFG + the 3 disk images from the *.zip-file you provided on it. (Mixed chorus etc...)
The HxC drive now works and I can chose between the different images on it. I can't load the disks. There is no contact with the emax. The emax-display is saying "Please insert disk!", and the buttons on the emax are stuck. Seems like the HxC is connected the wrong way.
Switch ID0A is on.
I provide some pictures here so its easier to see how its hooked up:
That should explain it! :)
Kna wrote: Mon Jan 15, 2018 2:47 pm Hi again.
Switch ID0A is on.
i can't see the pictures, but anyway try to reconnect the floppy ribbon to the other way.
Kna
Post by Kna »
Argh photobucket is killing me! Well, here are the pics again. Probably need to turn the floppy ribbon around, but just to be sure...
Kna wrote: Mon Jan 15, 2018 10:32 pm ..Probably need to turn the floppy ribbon around, but just to be sure...
This is for sure the current problem :wink:
Kna
Post by Kna »
You were absolutely right, turning the ribbon cable around solved the "Please insert disk"-problem.
Now there are new problems. :)
First of all, the SD-drive starts to automatically load a (pre)selected disk at startup, before I get a chance to choose what disk-image to load.
Is this a parameter in the config-file that dictates instant loading upon startup?
Anyway, Mixed Chorus gets loaded, it stops at 73/80 (dont know if this is as it should be?),
immediately after loading emax display shows "Wrong Software!" message.
This means that the emax and the disk-images have different OS-versions, right?
Kna wrote: Wed Jan 17, 2018 1:42 am You were absolutely right, turning the ribbon cable around solved the "Please insert disk"-problem.
Yes you uncheck the autoload function with the hxc software (sd hxc settings window)
Yes. You have to update/change the os on this disk, or boot up from the right OS.
Kna
Post by Kna »
Great, it worked!
Have now upgraded to SE1.1 and the factory library loads beautifully.
Thank you so much Jeff!
Now, some last questions, just for the sake of understanding:
In the SD config-file setup:
What is indexed mode?
What is the interface setting "Mode (From HFE)" ?
Why do the config-file apparently reset itself?
