New here with lotharek
jcpamart
Post by jcpamart »
I'm new in this univers, and was so saad to not use my old 520 STF.
So I have bought a lotharek floppy emultor in extern format.
I have a 2 go sd card.
On the lotharek website I don't find really a clear explication, so my question is simple.
Do you know where I can find a zip compli with a goog configuration to use this floppy disk emulator with a dos interface ?
Thanks a lot.
JC
Re: New here with lotharek
You want to use is it on a dos or an st machine ?
jcpamart
Post by jcpamart »
To use in a 520 Stf machine
jcpamart wrote: Wed Dec 27, 2017 7:46 pm To use in a 520 Stf machine
Then just put the default CFG file file and some HFE files on the SDCard.
jcpamart
Post by jcpamart »
Hi, thanks for your help.
I wanted to know if there is an image disk wich propose a dos interface like this :
https://www.youtube.com/watch?v=zQimURq ... effHxC2001
jcpamart wrote: Thu Dec 28, 2017 5:31 pm Hi, thanks for your help.
You mean the file selector ? yes sure :
https://hxc2001.com/download/floppy_driv ... anager.zip
jcpamart
Post by jcpamart »
Yes, so i'll try this WE.
But seems not working with my sd card.
I'll find another one to test with a new sd card, and i'll see.
Keep you in touch.
