Kaypro 2x disk
omegasigma
Kaypro 2x disk
Post by omegasigma »
Im sharing my disk that came with my kaypro 2x
the rom is a 81-478-A and the motherboard is a 81-581
has the kaypro plus clock program however due to original "time" not being Y2K compatable
Sharing this cause I don't have an actual means to transfer over Kermit and I wanted to have the master menu still.
Original.zip
(230.64 KiB) Downloaded 724 times
omegasigma
Re: Kaypro 2x disk
Also for anyone wondering I used jumpers 1 and 6 for the HXC to use double floppy mode, and only turned off 6 when I hooked up the original ribbon again to copy the original disk that came with the unit, the adapter can be found at "cable depot"
Re: Kaypro 2x disk
Thanks for sharing !
omegasigma
Re: Kaypro 2x disk
Im also including the Kaypro plus boot disk, from where I got the y2k Compatable clock program off of, this is meant for the kayplus rom. So not everthing has been tested on my machine.
KayPlus-Boot.zip
(186.39 KiB) Downloaded 753 times
