Problem with file selector scrolling up all the time
ppieczul
Post by ppieczul »
I use Gotek drive with FW v3.0.33.3a and HxC Floppy Emulator file selector v1.65a
There is a weird problem on one of Amiga 600: the file selection screen starts ok but the highlighted position is permanently scrolling up, like the up-arrow key was pressed on the keyboard all the time.
Now, why this is weird:
- the keyboard functions correctly, i.e. I can use other apps, for example workbench and every key works fine
- the problem does not occur on my other Amiga 600 nor on Amiga 500 and CDTV on which I use the same drive
- the problem does not depend on Kickstart version
- I also tested selector version 1.14a and the problem exists there too
I am pretty puzzled. Any help highly appreciated. Here is a video of the problem:
https://youtu.be/F_fkLu0IQqk
Re: Problem with file selector scrolling up all the time
For sure not an issue with the drive or the firmware. This is maybe a joystick input issue. The file selector can be used with the joystick. both joystick ports are working properly ?
ppieczul
Post by ppieczul »
Ah yes! I have figured out in the meantime also from the code that the menu can be operated with a joystick - I have never used a joystick for it.
I just replaced one of the capacitors on the board and it works all fine now. Thank you very much.
nice. all capacitors of all a600 in the world should be replaced :wink: :lol:
