What am I doing wrong ?
mal
Post by mal »
I have an HxC2001 which I'm using on two Amiga 500s but they both have the same problem (one KS1.2 the other KS2.0). In AutoBoot mode the selector appears but when I select a converted ADF file I just get the Amiga Kickstart insert disk screen. The HxC2001 clicks as if the Amiga is polling it but it never boots.
Basically the AUTOBOOT.HFE works but any HFEs I create are ignored. Could I be making a mistake in the ADF/HFE conversion ?
Thanks in advance
Mal
Re: What am I doing wrong ?
mal wrote: Fri Nov 17, 2017 5:39 pm I have an HxC2001 which I'm using on two Amiga 500s but they both have the same problem (one KS1.2 the other KS2.0). In AutoBoot mode the selector appears but when I select a converted ADF file I just get the Amiga Kickstart insert disk screen. The HxC2001 clicks as if the Amiga is polling it but it never boots.
Thanks in advance
Mal
What is displayed on the drive screen ?
mal
Post by mal »
It shows the name of the file on the top line and T:002/084 S:0 on the second. The drive clicks and the 002 changes to 000 then clicks and back to 002 again.
I've used the same device with a different SD card on my Atari ST and it worked fine in my limited testing.
Any help would be appreciated
Mal
Sound to be a floppy ribbon issue. Have you tried another one?
mal
Post by mal »
Thank you for the suggestion. I have now tried 4 different cables with the same results. 1 was the original that came with the Amiga and two are new ones I purchased for this project.
Any other suggestions ?
mal wrote: Sat Nov 18, 2017 3:08 pm Thank you for the suggestion. I have now tried 4 different cables with the same results. 1 was the original that came with the Amiga and two are new ones I purchased for this project.
The disk change signal doesn't work.
Please check :
-> That you are using the right files for Amiga. (HFE interface mode set to Amiga...)
-> Switch settings set to ID0-A.
-> That you don't have forced an interface mode into the device. to be sure, enter the internal menu and do a "clear eeprom".
-> Check the host machine : the floppy ribbon, the chips connections into there sockets... These some very common issues.
mal
Post by mal »
I've worked out the problem. It appears I hadn't been converting the ADFs to HFEs correctly. I think I had to specifically set the Amiga option in the settings of the conversion program rather than using the Auto setting.
I did find a few sample HFE files that someone had posted here for you to test. I used them and they worked OK so I knew the problem wasn't hardware. I also spoke to Phil from the local Amiga Users Group who was very helpful. I think I was over thinking the task.
Anyway, all good now.
Thank you all for your help
Mal
Ok fine then :D !
