HXC rev F (can not save)
Tonton
Post by Tonton »
Hello
I have a problem with my HXC rev F
I can not save, it says to me every time "No Data Transfered"
I have no problem loading sound and sequence from disk images
but can not be saved
either I do not understand the manipulation
I have to try several sd, I even try to format with the SP1200 but it is always the same, of where could come the problem ?
help me please
Re: HXC rev F (can not save)
Have you tried another floppy ribbon ?
Tonton
Post by Tonton »
Merci pour le retour Jeff
je vais essayer avec un autre Ribbon et te tiens au courant
si quelqu'un d'autre a déjà eu se problème ? merci pour son retour
Thanks for returning Jeff
I will try with another Ribbon and keep you informed
if anyone else has ever had problem? thank you for his return
