kryoflux raw to hfe
David g
kryoflux raw to hfe
Post by David g »
OK Newbie here. Got myself a kryoflux. I am using the dodumpcpc batch file with it . I end up with 42 files per side. How on earth do I convert these to HFE for the HxC emulator?_Using the batch converter gives me 42 HFE files per side. Putting these on the SD card gives me no ability to read and run the disc. What am I doing wrong?
Re: kryoflux raw to hfe
David g wrote: Sun Oct 01, 2017 1:29 am OK Newbie here. Got myself a kryoflux. I am using the dodumpcpc batch file with it . I end up with 42 files per side. How on earth do I convert these to HFE for the HxC emulator?_Using the batch converter gives me 42 HFE files per side. Putting these on the SD card gives me no ability to read and run the disc. What am I doing wrong?
Don't use the batch converter. Just drag & drop ONE .raw file. the software will load the others raw track automatically.
Once done, have a look to the track viewer to check that the import/conversion look fine, then export to HFE.
David g
Post by David g »
Thank you. I will try this later.
I appreciate the really fast reply.
David g
Post by David g »
It works,many thanks. A genius out there.
Now I can get to work on these 400+ discs.
