Support for TRS-80 Model 4P
retrobecanes
Post by retrobecanes »
I have been using HxC on my Amiga 500 and wanted to use it on my newly acquired TRS-80 Model 4P as well.
A few questions:
- does the HxC get connected directly to the internal floppy connector?
- Is there an autoboot.hfe option as well for the TRS-80? Do commands need to be entered on the TRS-80 to enable that feature?
- Any other setup/configuration options I should be aware of when using HxC on the TRS-80?
/Retrobecanes
Re: Support for TRS-80 Model 4P
yes. maybe an edge adaptor is needed.
not yet. Use the normal mode.
nothing special.
