GEM S2/S3 img files to hfe?
jansjobe
Post by jansjobe »
Hi!
Just got my HxC working in my GEM S3. Fantastic!
But I've got a ton of Omniflop .img files (1600kb) with sounds, and I can not convert them to hfe.
I think I tried everything, but most certainly I did not...
Can someone help???
Best Regards,
Jan
Re: GEM S2/S3 img files to hfe?
Use the HxC Software :
->Load Raw Image -> Set "Predefined Disk Layout" to Gem S3 HD Floppy Disk. -> Load Raw File -> export.
you can also use the batch converter to convert all your files in one pass.
jansjobe
Post by jansjobe »
Jeff, I have tried that. Does not work...
jansjobe wrote: Wed Sep 13, 2017 12:29 am Jeff, I have tried that. Does not work...
then please share : your working hfe, your non-working hfe + its .img file. i will check where is the problem.
joemanu
Post by joemanu »
Dear all just to confirm the batch conversion works perfectly.
I converted all deepsonic.ch samples for GEM S series (raw IMG files to HFE)and tried converted files on my workstation GEM S2 it works great.
I just wonder why from an IMG file of 1.6MB we reach 3.9MB in HFE file format, anyway still lot of space on USB stick.
Thanks for your forum and all good things shared.
