IBM PS/2 P70 floppy adapter
k-Tracker
Post by k-Tracker »
Hello Jeff, would you please advise, if there are any known adapters to connect HxC emulator to P70? it's using 34pin connector too, but a power supplied through the convertor as well. Any leads to to the information are highly appreciated.
Re: IBM PS/2 P70 floppy adapter
k-Tracker wrote: Tue Sep 05, 2017 4:01 am Hello Jeff, would you please advise, if there are any known adapters to connect HxC emulator to P70? it's using 34pin connector too, but a power supplied through the convertor as well. Any leads to to the information are highly appreciated.
you need to cut this power line and redirect the +5V to the +5V hxc input.
