cxc floppy emulator problems
epsbasse
Post by epsbasse »
I got the floppy emulator this week and i was exited to install it on my Ensoniq EPS Classic. In my case i got a problem, i opened up the EPS and installed the floppy emulator but i can't read any sd cards or nothing. When i power on the eps the floppy emulator begins to make this weird noise from time to time and both of the red lights are on. In the upper field of the screen of the floppy emulator it only shows me a black strip, nothing more, nothing less. So my question here: is the floppy emulator broken or is it some kind of error? What is the problem here?? I would love to get this beast started but i can't right now as it seems... I attach a link with a photo so you can see for yourself. Any suggestions?
PHOTO: https://imgur.com/a/NlXzG
Best regards!
Re: cxc floppy emulator problems
You may have this when the input voltage is too low (<4.5V).
Check that all is correctly connected and check the 5V voltage of the ensoniq.
