Buzzer for Gotek
elluigi
Buzzer for Gotek
Post by elluigi »
As describe in the README_USAGE.TXT :
- Buzzer sound output -
You can connect a piezo or a magnetic buzzer to the JB jumper position.
A transistor is needed for the magnetic version.
The sound output can be disabled or enabled into the selector settings.
(Note : Please remove these old sound mod using directly the floppy step signal, they are producing reliability problems...)
Is that "Buzzer 30V 13x2.5mm Piezo Passive Buzzer" good for the gotek connecting to the JB position WITHOUT transistor ? :?:
http://www.ebay.com/itm/10pcs-SMD-Buzze ... Sw4CFY0jc5
If this item was not good, do you have a reference that i could buy without needing a resistance ? :D
THX for your response.
Re: Buzzer for Gotek
Yes this one can be connected directly. But i am not sure if the the sound output power is enough.
elluigi
Post by elluigi »
OK merci.
Du coup si je met un buzzer magnetic, je dois mettre quelle résistance ? sur quel broches ? Désolé si la question parait redondante mais je n'ai pas trouver l'info (en plus de ce que j'ai compris avec la nouvelle version il faut oublier les anciens mod buzzer).
elluigi wrote: Thu Aug 31, 2017 3:55 pm OK merci.
Pour les buzzer magnétiques, c'est le meme montage avec transitor qu'avant, sauf qu'il faut connecter l'entrée sur la sortie JB et non plus sur le signal step du floppy.
elluigi
Post by elluigi »
OK parfait merci de ta réponse.
xadox
Post by xadox »
Should the buzzer be an active or a passive one?
xadox wrote: Tue Sep 05, 2017 10:02 am Should the buzzer be an active or a passive one?
passive.
teevee
Post by teevee »
Hi did you test those buzzers you bought above? :)
I found this good video, which explain how to install this and I ordered 10 of those due to that the guy mentioned, that it should work for HxC flashed devices too. It really makes me mad with this “silence” :D
https://www.youtube.com/watch?v=UevBaQvG_4Y
Follow this and all will be fine :
