Atari St with Gotek / HxCmount file > 32 MB image file ?
elluigi
Post by elluigi »
I would like to thanks Jeff for his great HxC firmware with Gotek ! It run perfectly :P
I'm trying to use HxCmount, and i would like to know if there is a way to create a > 32 MB image file ?
Thx for your support :D
Merci Jeff pour ce fantastique firmware, cela fonctionne tu tonnerre :P
Je suis en train de regader pour utiliser le HxCmount et je souhaiterais savoir s'il existe une solution pour créer des partition > 32 Mo ?
Merci par avance :D
elluigi
Re: Atari St with Gotek / HxCmount file > 32 MB image file ?
Post by elluigi »
no-one ? :roll: :cry:
elluigi
Post by elluigi »
:roll:
elluigi
Post by elluigi »
UP
elluigi wrote: Wed Sep 27, 2017 12:02 pmUP
Better to ask to some Atari specialists... i think that a special driver is needed but i am not sure at all...
