an idea .... third button activation in autoboot
GROUPGLOBAL
Post by GROUPGLOBAL »
an idea...
is it possible to add a fuction in the filebrowser settings, to activate the third button in autoboot mode? "(e.g. THIRD BUTTON on/off)"
then for example you can press short to insert a disk and a long press to eject it?
so is also enough time to scroll the filename in lcd display, when i will change the disk and search the right filename!
GROUPGLOBAL
Re: an idea .... third button activation in autoboot
You can already eject/reinsert images by pressing both button in the same time.
aotta
Post by aotta »
Jeff wrote: Thu Aug 24, 2017 4:35 pm You can already eject/reinsert images by pressing both button in the same time.
Does this works in normal mode to, for selecting disks or folder? i'd like to stop drilling cases and soldering third buttons! :D
