Problem with Filebrowser on Amiga
GROUPGLOBAL
Post by GROUPGLOBAL »
hi there,
i have two problems with HxC in an Amiga500
currently i have the newest alpha Firmware and autoboot.hfe on it
in filebrowser, i can not get to the upper directory. right shift and ".." have no effect.
i have to save and reboot the amiga
i have only one file in filebrowser selected, but my lcd display says 000 -- 003 why 003?
000 = autoboot.hfe
001 = selected file
002 = ???
003 = ???
GROUPGLOBAL
Re: Problem with Filebrowser on Amiga
GROUPGLOBAL wrote: Sun Aug 20, 2017 2:45 pm hi there,
000 = autoboot.hfe
001 = selected file
002 = ???
003 = ???
GROUPGLOBAL
A new firmware release was just there fixing the total slots numbering issues. Update your firmware and let me know if this solve your issue.
GROUPGLOBAL
Jeff wrote: Sun Aug 20, 2017 6:56 pm A new firmware release was just there fixing the total slots numbering issues. Update your firmware and let me know if this solve your issue.
i test it now and the Display now shows the correct numbers . Perfect!
But the problem with the filebrowser is still available.
GROUPGLOBAL
Can you make an image of your usb stick, pack/zip it and send it to one of my ftp server ?
GROUPGLOBAL
I have tried two usb sticks
I've tried using only two and with many directories
Always the same problem
Have made a video, so you can see it.
It always jumps to the slots
I have already formatted several times and the files again copied. no success
Of course I make you a copy of the usb stick, which one sees in the video
Here the video link:
(problem fixed now, video deleted)
GROUPGLOBAL wrote: Mon Aug 21, 2017 7:48 am I have tried two usb sticks
https://www.youtube.com/watch?v=f6Ztc3Sq4ao
Oh ok i see now ! I will try to reproduce this now. EDIT: I can... fixing now...
GROUPGLOBAL
Jeff wrote: Mon Aug 21, 2017 9:09 am Oh ok i see now ! I will try to reproduce this now. EDIT: I can... fixing now...
SUPERB!!
GROUPGLOBAL wrote: Mon Aug 21, 2017 9:27 am
SUPERB!!
Fixed :
Thanks for the report !
(and let me know if this fix the issue for you of course ;) )
GROUPGLOBAL
Jeff wrote: Mon Aug 21, 2017 10:02 am Fixed :
Hi Jeff!
THX for this fast Fix and for your great work!
Now everything works perfectly!
:D
