Hi there,
I'm fairly new to this HxC world and I'm not a programmer but understand a tiny bit. So sorry if this has been covered before (I've read other posts but couldn't find what I'm after):
I'm about to get a HxC floppy emulator for my Miracge rack sampler and I have 10-15 floppy disks. How would I have to convert them, i.e. what software would I have to use in order to transfer them onto HxC? Once the floppy drive is not there anymore I won't be able to read the disk on my Mirage.
Probably this is a trivial and silly question but I'm trying to figure this out having also other samplers I'd love to upgrade to HxC
Software to convert Mirage disks
Re: Software to convert Mirage disks
Have you a pc with an internal floppy drive ?
yes! Also a Mac if needed
any news about the Mirage software (for Mac or PC)?
Best regards
If they're custom (homemade) disks, use Omniflop in a PC with an internal floppy drive to read the disks to an image and then convert to HFE with the available HxC software.
If they're stock disks, chances are they've already been converted here: http://r-massive.cellarseer.com/ensoniq ... e-library/
And why not use the dump tool present inside the hxc tool ?mondo1976 wrote: Wed Aug 09, 2017 3:04 pm If they're custom (homemade) disks, use Omniflop in a PC with an internal floppy drive to read the disks to an image and then convert to HFE with the available HxC software.
If they're stock disks, chances are they're already been converted here: http://r-massive.cellarseer.com/ensoniq ... e-library/
Great, thanks a lot!
Honestly, it just doesn't work as well, in my experience. Omniflop works 100% of the time and I can't argue with that success rate. HxC Tool is always warning me I don't have something installed or configured correctly, etc. and I already know Omniflop is going to work perfectly.Jeff wrote: Wed Aug 09, 2017 3:44 pmAnd why not use the dump tool present inside the hxc tool ?mondo1976 wrote: Wed Aug 09, 2017 3:04 pm If they're custom (homemade) disks, use Omniflop in a PC with an internal floppy drive to read the disks to an image and then convert to HFE with the available HxC software.
I don't find Omniflop so good. If you don't want to use the hxc tool, i always recommend ImageDisk instead that work properly and produce "true" image with a description of the disk format (*.IMD). With this file format, the disk format is not lost and you can just convert the image without asking the disk format to apply. Maybe that now there is a better file format with omniflop ? if not i can't recommend it.mondo1976 wrote: Wed Aug 09, 2017 4:36 pmHonestly, it just doesn't work as well, in my experience. Omniflop works 100% of the time and I can't argue with that success rate. HxC Tool is always warning me I don't have something installed or configured correctly, etc. and I already know Omniflop is going to work perfectly.Jeff wrote: Wed Aug 09, 2017 3:44 pmAnd why not use the dump tool present inside the hxc tool ?mondo1976 wrote: Wed Aug 09, 2017 3:04 pm If they're custom (homemade) disks, use Omniflop in a PC with an internal floppy drive to read the disks to an image and then convert to HFE with the available HxC software.
btw it is possible that the omniflop driver broke the standard floppy driver and make the other tool non-working (hxc for example). i remember to have got this issue.
This could very well be the case as it does use alternate drivers. Be that as it may, I need floppy images for things other than HxC, so I do not wish to strictly use the HxC software -- therefore, I must use a third-party tool and Omniflop can serve both purposes. ImageDisk may be fine, but personally I do not wish to store headers/footers/descriptions in with a disk rip. I only want the raw data, and besides, anyone messing with a disk rip should really know the target machine (and therefore disk type & format) they are dealing with or else what are they even hoping to achieve?Jeff wrote: Wed Aug 09, 2017 5:01 pmbtw it is possible that the omniflop driver broke the standard floppy driver and make the other tool non-working (hxc for example). i remember to have got this issue.
Just a philosophical/workflow difference, I suppose. I know my method works 100% of the time and I can't say that for other methods, so that's simply what I recommend. Your mileage may vary, as they say.
I guess I should add that I don't work with anything copy-protected or particularly sophisticated, so my needs are more basic than what ImageDisk, KryoFlux, et al do.
P.S. Thank you so much for the new Gotek firmware efforts. What a great update!!!
