ERROR: Can't open HXCSDFE.cfg (DF1/A1200)
Xnyle
Post by Xnyle »
I just flashed a Gotek, downloaded everything from the bottom of https://hxc2001.com/download/floppy_driv ... /#stm32hxc
and tried to boot from DF1 via early boot menu.
So far so good, autoboot.hfs boots up but displays the error in the subject.
I tried several USB sticks, 4/8/16GB, old new, all the same.
Sticks are always formatted as FAT32 and first file copied on them is HXCSDFE.CFG followed by AUTOBOOT.HFE, nothing else yet.
Any suggestions?
Xnyle
Re: ERROR: Can't open HXCSDFE.cfg (DF1/A1200)
Post by Xnyle »
Next Problem in Indexed Mode:
All disks (copied AUTOBOOT.HFE as DSKA0000.HFE, DSKA0001.HFE) are write protected?
DSKA0002.ADF isn't detected at all, even if I delete all HFE files and rename it to DSKA0000.ADF?
Xnyle wrote:Hi,
Any suggestions?
If you can make a low level image of your usb stick, this may help me to understand the issue.
