Key Mapping in search
Torgo
Post by Torgo »
Any one having this issue? When using the search feature, the keys are not mapped out properly. For example your press A and R pops up in its place.
Once you boot into the ST software it reverts back to normal.
Thanks guys....
Torgo
Re: Key Mapping in search
Post by Torgo »
Torgo wrote:Any one having this issue? When using the search feature, the keys are not mapped out properly. For example your press A and R pops up in its place.
Thanks guys....
Any one out there???? Or is everyone not experiencing any issues with this. Some feed back would be nice.
namachari
Post by namachari »
I'll check again tonight for you, but last time I did a search (about a week ago) it worked fine...although a little slow as I have a lot of images.
Phil
namachari
Post by namachari »
Hi again,
Well, yes, you are correct. Some keys are not mapped correctly, whereas some keys are. Weird!
An obvious one for me is 'a' is 'q' and visa versa...plus many more.
Phil
Torgo
Post by Torgo »
Thanks.. i thought i was going nuts.. :)
Torgo wrote:Thanks.. i thought i was going nuts.. :)
will check the issue.
but anyway the original keys mapping is based on an azerty/french keyboard. This may explain the issue ;)
namachari
Post by namachari »
That would be great.
