Kryoflux Akai S950 Dump and conversion to HFE
mikedean
Post by mikedean »
I am trying to dump some of my old Akai S950 disks using Kryoflux and then convert to HFE and load in hxc flashed gotek. So far I have tried dumping as CT Raw, and Kryoflux Stream, Preservation. I then load the raw files into HxC Floppy Emulator v2.1.6.0 and export as hfe. When I load hfe in S950 sampler the disk is empty. I have other images that I have downloaded that work fine. None of my images seem to work. Anyone have any experience dumping S950 disks to hfe?
Mike
5c4r7
Re: Kryoflux Akai S950 Dump and conversion to HFE
Post by 5c4r7 »
Hi there,
Did you ever figure this out? Do you of any documentation which describes how to extract s950 files to .hfe format for the HXC?
Any assistance is greatly appreciated.
-s*
5c4r7 wrote: Sun Jan 20, 2019 6:35 am Hi there,
-s*
what do you mean with "s950 files" ?
5c4r7
Post by 5c4r7 »
I have a kryoflux and a Windows pc with a floppy and omniflop. Do you know if anyone posted instructions on how to extract also s950 floppies and then convert them to a readable format for the HXC? Everything I have tried so far is not working. I have an HXC type f installed.
5c4r7 wrote: Sun Jan 20, 2019 5:00 pm Hi Jeff,
With kryoflux raw preservation images :
-> Start the hxc software
-> Drag & Drop one and only one raw file on the main window
-> Wait...
-> Track Analyzer Button
-> Disk view mode Radio button
-> Check that all is fine (no bad sector and 800 sectors/819200 bytes of data on each side)
-> Close the Analyzer window
-> Button Export
-> Save (IMG file / RAW Sector file format)
At this point you have an "omniflop image"/img version of your kryoflux preservation dump. Just follow the above procedure to generate an hfe file from these raw/omniflop image:
With omniflop/img images (S950 images should have a size of 1.6MB) :
-> Button "Load Raw Image"
-> In "Predefined Disk Layout" choose "Akai S950 3"5 HD Floppy Disk"
-> Button "Load Raw file"
-> Choose the omniflop file image
-> Button Export
-> Save (to the default HFE file format)
