Floppy Drive Manager on the ST with Gotek
paulnott1234
Post by paulnott1234 »
I'm trying to get a Gotek with HxC firmware running with my Atari ST.
I have brought the firmware up to date with the latest version and installed it.
I downloaded the Floppy Drive Manager for Atari ST, and have run into the following issue;
- the autboot.hfe loads up ,and I can move *.st files into different slots.
- I can then reboot and it loads up the slot with the game
This all works fine, but if I then select slot 00 to get the manager back, it loads but with the 2 or 3 bomb symbols.
The manager is unusable in this stage and I have to re-apply the files to the USB drive.
Any ideas what is going on? I've tried different combinations of jumpers (SD0, MOT on and off - which is correct?)
I've also tried recreating the CFG file with the HxC software - doesn't seem to help.
Cheers,
Paul
Re: Floppy Drive Manager on the ST with Gotek
This is probably a boot virus present on one of these game image that alter the autoboot.hfe.
paulnott1234
Interesting, I hadn't thought of that.
I'll try some different .st files and see if I can get a different result.
Cheers Paul
Lambouk
Post by Lambouk »
Hi mate.
Can you please post the link for the floppy drive manager?
Also how do you update the firmware?
Steve
namachari
Post by namachari »
I've come across the same problem. A shut down, and power fixes the issue.
P
tzok
Post by tzok »
If you have TOS 1.06 or newer try Alt+Ctrl+Shift+Delete...
