Mirage not completely loading images?
vgtblintl
Post by vgtblintl »
Hi y'all! I just got my HxC emulator (SD version) a couple of days ago and have it installed in my Ensoniq Mirage DSK. Everything appears to be set up correctly but most .hfe files I use only load 11/80, then up to 27/80. The screen on the Mirage shows "21" but if I try pressing any buttons it will eventually turn to "--". The strangest thing is I was able to load up to 79/80 using the Soundprocess .hfe file and all the buttons were working. Any ideas? Thanks so much!
kadoat
Re: Mirage not completely loading images?
Post by kadoat »
Did you ever find a solution? I'm facing the same problem.
Bruno79
Post by Bruno79 »
Hi there, same problem here. Did you find a solution? I'm going crazy with that. Please help me :(
Probably an image issue. Which one are you using ?
