SDCard HxC Floppy Emulator writing question
LeoNardo
Post by LeoNardo »
Hello Jeff, i build the SDCard HxC Floppy Emulator rev A and is working great in a A500, I have a question about writing..
I load the workbench 1.3 and when i want to save changes on preferences I have this message ¨WEOE¨ that appears at the right of the track on the lcd.. I dont know what that mean, and the changes are not saved...
Can you help me?
Thanks in advance.
Sorry for my poor english..
Leo.
Re: SDCard HxC Floppy Emulator writing question
LeoNardo wrote:Hello Jeff, i build the SDCard HxC Floppy Emulator rev A and is working great in a A500, I have a question about writing..
Can you help me?
Thanks in advance.
Leo.
The SDCard HxC Floppy Emulator are in read only mode for Amiga.
DrPluto
Post by DrPluto »
if you could please help me to clarify this for my simple mind, regarding the SD card HcX emulator and the Amiga...
So in simple terms does not being able to write mean not being able, for example, to save games?
Could the hardware or software be modified so as to make it writeable for the amiga? How difficult would it be to make this modification?
Are there any plans for a future version, which will include write support for the amiga?
Or would uit be possible to have the original floppy drive plus the SDcard emulator both connected, and so write to a floppy disc instead?
Thanks for the help, just want to understand what it is exacly I might be buying!
lotharek
Post by lotharek »
no chances to modify software/hardware to support amiga writes.
serach throuhout the forum
..... Atari Roxxx !!!
fabu
Post by fabu »
Hxc received today .
SD card 2go Sandisk formated in fat32 --> no card found ?
SD card 2go Sandisk formated in fat --> card ok. SDHXCFE.CFG not found ?
I copied HXCSDFE.CFG.
That must me make?
Thank !
fabu
Post by fabu »
Jeff .Card not found in fat32 ?
fabu wrote:Jeff .Card not found in fat32 ?
What is the OS did you used to fomat this sdcard ? Windows XP, Seven, or something else ?
Try a low level formatting with this tools :
http://www.sdcard.org/consumers/formatt ... EN2905.zip
fabu
Post by fabu »
Windows XP
fabu wrote:Windows XP
ok
try to make a low level format with this tools :
(Option -> Format type -> FULL (Erase On) )
and after this reformat the sdcard in fat32 with windows.
fabu
Post by fabu »
Yes. its OK !
Thank you Jeff ! :D
