Arburg dialogic FS Dos
bokito
Post by bokito »
Helo Jeff, Sorry for mu bad English
I bought the HxC Emulator and i want to use with Arburg Dialogica who use DOS file system
Can HxCFloppyEmulator software directly on PC read this type of file system and create image that i can use on my HxC Emulator
Thank you
bokito
Re: Arburg dialogic FS Dos
Post by bokito »
Is there is someone on forum that can help me?? :? :|
FS Dos. So these disks are readable by a PC computer ?
pismerovvasb1
Post by pismerovvasb1 »
Hello Bocito!
When the Arburg 320D_210_270 injection molding machine is turned on, a system floppy disk is requested. I insert the floppy disk, the download does not occur. I read this floppy disk using Kryoflux, uploaded the Raw files to the HXFLOPPY Emulator — the floppy disk is damaged. I need a system floppy disk (with any serial number) or an Hfe file is required., for the SD Hc Lothatec disk drive emulator. Injection molding machine -Arburg with the Hydronic_Dialogic control system.
Thank you.
