Yamaha SY77
chrispoacher
Yamaha SY77
Post by chrispoacher »
Hi, does anyone know the correct jumper settings for a flashed Gotek drive with hxc in a Yamaha SY77? Mine picks up the drive and key but when i load a file i just get a bad disk error. Is there a config file i can download also please. Chris
Additional :-
I've found the correct jumpers now, but i'm having trouble with images created with the hxc floppy emulator Software. Strangely enough, if i format the image that the SY calls 'bad disk' on the Yamaha SY itself, they format fine. Then i can save files to that formatted image all ok and even load the saved files back in perfectly.
I can load that new image into the hxc emulator software ok, delete the files and add new ones (720k PC disk format) and export; load it back into the SY and surprise surprise, bad disk error again. :(. Can anyone help me fix the problem?? I don't really fancy saving hundreds of files manually this way by dumping them via sysex thru midi when i could simply create the images on the pc properly in a fraction of the time.
Additional 2..
I found now that if i write the files to a real 720k floppy disk, then re-grab it using omniflop, then convert that image using the hxc software and export it to a .hfe file, it works fine. So what is going wrong with the normal create a dos disk and export in v2.1.6.0 software??
Chris
Re: Yamaha SY77
Share the working and non images.
chrispoacher
Re: Yamaha SY77
Ok I will email them in the morning.
Silagemaker
Re: Yamaha SY77
Post by Silagemaker »
Hi chrispoacher
Since I've just got an SY77 any way you could help
me set it up.
See this thread
https://hxc2001.com/floppy/forum/viewtopi ... 663#p15663
Cheers and thanks
midiquestions
Re: Yamaha SY77
Post by midiquestions »
Did you ever get the SY77 working? I also have one and would love to replace the floppy drive.
Re: Yamaha SY77
midiquestions wrote: Wed Jul 12, 2017 7:04 pm Did you ever get the SY77 working? I also have one and would love to replace the floppy drive.
In fact yes, but it seems that there is a compatibility problem with the disk browser present into the hxc software and the SY77. chrispoacher didn't send me the images so i can't fix the issue for the moment.
Anyway you can use a third party software like winimage to create your floppy images.
talmic
Re: Yamaha SY77
Post by talmic »
Un adaptateur 26->32 pins est obligatoir.
Configuration des jumpers du Gotek pour le Yamaha SY77: S0+MO
Formatage PC: MSDos 720Ko
Lecture, enregistrement et formatage avec le SY77: OK
Création image avec OmniFlop et hxc floppy emulator Software: Ok
Re: Yamaha SY77
talmic wrote: Wed Apr 11, 2018 5:31 pm Un adaptateur 26->32 pins est obligatoir.
Thanks for the feedback.
Translation :
26->32 pins adapter needed.
Jumper setting to use : S0 + MO
Format : MSDOS/FAT 720KB
Read, Write, Format with the SY77 : OK
Image creation with OmniFlop and HxC Floppy Emulator Software : OK
