Gotek on the Falcon
mikro
Gotek on the Falcon
Post by mikro »
Is Falcon officially supported for Gotek? Because I can't get it working at all -- same drive, same usb stick, same jumpers (S0, MO) as used on my STE and ... A: is not responding. Both Gotek and keyboard LEDs go on and off after a while so something is happening but that's it. Neither the manager nor empty disk image work.
mikro
Re: Gotek on the Falcon
Post by mikro »
Mystery solved: http://www.atari-forum.com/viewtopic.ph ... 72#p312972
Apparently, the floppy cable on the Falcon is connected other way around so you don't need to flip anything (but it looks horribly wrong!)
Nothing is simple in this world ;)
