Akai S950 Question.
ssanoo
Akai S950 Question.
Post by ssanoo »
hi. i got some question about Akai S950.
i install a Gotek drive with HxC flashed.
and it works but here's question.
i knew we can use 1000 floppy images.
i downloaded "QuickInstall FloppyDiskImages."
and i found Zip file for S950, there's only 30 Images.
so here's question.
does it works if i just copy and paste that image files?
i mean just copy DISKA0030.HFE and rename it as DISKA0031.HFE and 0032, 0033, 0034...
i also have HxC Rev.F for my SP1200. and there's only 100 images. can i copy and paste it too?
and i wonder does it works if change images name.
well, S950's image names OK but Sp1200's image name starts EMPTYDISK000
so i want to change it like just DISK000. :)
please let me know. tell me you guys experience.
and if i can do that, is there some program which is copy and rename it at once?
i can't do that 970times..:))
thanks for your reply. :mrgreen:
Re: Akai S950 Question.
Yes you can copy/paste the images.
You can made a batch file to copy them 1000 times.
teevee
Post by teevee »
Jeff wrote:Yes you can copy/paste the images.
do you have a simple .bat file for duplicating the images? :)
I tried making one myself and it went fine from DSKA0000 -> DSKA0009. I had problems with telling my .bat to go from DSKA0009 to DSKA0010 -> DSKA0999
