Ensoniq EPS 16 +
lowcust
Ensoniq EPS 16 +
Post by lowcust »
hello
just trying one of the hxc floppy emulator running on my ensoniq eps to, until now without success ?!
ensoniq format:
http://www.youngmonkey.ca/nose/audio_te ... rmats.html
http://www.ensoniqsamplers.com/epsasr/022.html
many thx, best regards thomas
Re: Ensoniq EPS 16 +
lowcust wrote:hello
ensoniq format:
This don't works because the ensoniq use sector id "0". I need to add this support in the software.
Where i can found some file images ? how do you load the file image in the software (did you use the "load raw image" function "?).
lowcust
Post by lowcust »
hello jeff
have some files with "load raw" fm and mfm settings tried, but always stopped from track 1. that would be great if it's working :D here are some images,
ensoniq eps 16 format .efe, rawread format and an image made by omniflop of ensoniq os1.30
http://beitegeuze.com/ensoniq.rar
thank you, best regards thomas
lowcust wrote:hello jeff
New software release: in the load raw menu a new parameter was added.
For example with ensoniqOS.img (819200 bytes) use these parameters :
Sector per track = 10
Sector ID start = 0
GAP3 lenght = 40
For 737280 byte file images:
Sector per track = 9
Sector ID start = 0
For *.ede files i need a description of this format to add a direct support in the software.
Sector ID start = 0
GAP3 lenght = 40
Sector ID start = 0
Update : the EDE file format is now supported;-).
Please give me a feedback.
lowcust
Post by lowcust »
Sector ID start = 0
GAP3 lenght = 40
Sector ID start = 0
hi jeff
i am so happy, the load of .ede eps16+ os works fine. import the the. img files (samples, sequences an effects) via "load raw" work but only the load of instruments "samples", sequences and effects do not work with .ede unfortunately.
anyway, great support, it is a real enrichment for all ensoniq synthesizer/sampler users and the market of floppy dependent instruments maybe also lucrative and above all necessary there is no affordable alternative.
I'll also make a youtube video of the korg dss-1 and try to create some pictures.
thank you very much for your help, best regards thomas
lowcust
Post by lowcust »
Sector ID start = 0
GAP3 lenght = 40
Sector ID start = 0
hi jeff
sorry: I'll also make a youtube video of the esnoniq eps16+ and try to create some pictures.
lowcust wrote:
hi jeff
what's wrong exactly ? any error message ?
lowcust
Post by lowcust »
lowcust wrote:
hi jeff
The error was on my side, sorry. I have tried to load a .efe file. i am also read out floppy with sounds on it, I realized that this floppys .efa or .efe endings had. but these files can I use in omniflop. img convert and import with load raw option.
able to find these infosabout .efe: http://thoralt.ehecht.com/download/efe.txt and here: http://www.thoralt.de/download/Ensoniq_ ... Format.pdf
sorry for my errors, I was too euphoric to watch closely on the file extension. big thanks, thomas
[/img]Image
lowcust wrote:
lowcust wrote:
hi jeff
[/url]
So all is working as expected (ede and raw loading) ?
lowcust
Post by lowcust »
lowcust wrote:
Jeff wrote: what's wrong exactly ? any error message ?
[/url]
yes, raw and ede are working. only recognizes the ensoniq not a change of the "floppy" file and must change manual the mode between ds0 amiga, atari st, amstard and msx 2 so that the ensoniq recognizes as a new floppy can be loaded.
lowcust wrote:
lowcust wrote: The error was on my side, sorry. I have tried to load a .efe file. i am also read out floppy with sounds on it, I realized that this floppys .efa or .efe endings had. but these files can I use in omniflop. img convert and import with load raw option.
[/url]
This probably due to a bad setting (select line and/or floppy interface mode). do you have the schematic of the EPS-16 ?
Regarding the efe file format, it seems that this is not a floppy image, but a file image. So i need to rebuild the full eps-16 filesystem and add this file on this fs. Are there some pc conversion utility (efe->floppy, or efe->ede) that does this work?
lowcust
Post by lowcust »
lowcust wrote:
Jeff wrote: So all is working as expected (ede and raw loading) ?
The Panasonic JU-257A - 303P http://beitegeuze.com/fd.jpg
should be Shugart, but the settings in HxC do not work as Shugart only as amiga, atari or mcx 2. the jumper settings of the original drive are ds0, ms, ry and ex, but i dont know for what is possible.
unfortunately i can not find under xp a runnable efe to ede converter, efe an efa files are audio samples files with data of tune, loop ... and the types of instruments. .efe for eps 16 and .efa for ASR 10.
perhaps you will find here information: http://thoralt.ehecht.com/ensoniq.html[/img]
lowcust
HxC SD Card Emulator on Ensoniq EPS16+
Post by lowcust »
first test with the SDCard HxC Floppy Emulator on my old Ensoniq EPS16+ sampler. works great!
http://www.youtube.com/watch?v=r09ZJPwi3eU
Re: HxC SD Card Emulator on Ensoniq EPS16+
lowcust wrote:first test with the SDCard HxC Floppy Emulator on my old Ensoniq EPS16+ sampler. works great!
Thanks for your feedback ! :D
