nready 2 firmware
wassim
nready 2 firmware
Post by wassim »
Dear jeff,
I need you'r help having bought some twenty hxc emulators from your lotharek colleague, I tried to run them on several different machines, thanks to your forum torlus i did it with a lot of machines but it happens that I remain blocked with a particular machine .
After being informed and seeking on your forum torlus I think that the solution to my problem is in the configuration pin 34 i need an nready 2 configuration that i can't find on the original firmware 1.8.2.40 received with lotharek emulator's .
so i found this solution in this link of your forum and hope you will help me .
https://hxc2001.com/floppy/forum/viewtopi ... =28&t=1225
Can you please send me a firmware which would allow to resume the option nready 2 in the parameters of personal configurations of pin 34 and pin 2.
I currently use emulators with firmware version 1.8.2.4 but do not include nready 2 in the parametrage.
Thank you for your help .
Re: nready 2 firmware
wassim wrote:Dear jeff,
wassim
Post by wassim »
Dear jeff ,
thank you for you'r answer i just tried the firmware link you sent me ,the emulator give on soft version :V1.8.6.14aL :2A89 but still no nready 2 on pin34 configuration .
Thank you for you'r help .
Best regards
What is this machine ?
wassim
Post by wassim »
Sorry jeff for the delay, so one time i had a problem with an akai mpc3000 and the second time was with a very old machine used for making iron coil the name of machine was tank yst07.
I hope the nready 2 option will help for this or another case,cause i tried every configuration one by one between the pin 2 pin 34 the jumpers ...
Thank you
