Kaypro 2: can I run Hxc with my (good) floppy?
hails
Post by hails »
Hi -Hxc doing great :-)
But I do want to get my 5.25" floppy drive to work at the same time. I've got a twisted cable and dip switches 1 & 6 are on.
My old floppy which works great on its own I've tried it as A and B by changing the floppy jumper.
I've also tried it with 6 OFF.
Is there something else I should try?
What about terminators?
cheers in advance!
hailey
hails
Re: Kaypro 2: can I run Hxc with my (good) floppy?
Post by hails »
I should have mentioned: my objective is to always boot from HxC (as A:) and use the floppy as B:
Would be nice to copy files between HxC and my real floppy :-0
H
Set ID0-A on the floppy emulator, and set the drive jumpers as the second drive.
hails
Post by hails »
Hi Jeff - just tried that, and no luck. Interestingly if I go to B: and do a directory listing the HxC clicks and gives me an identical directory listing of the A: drive!
(drive lamp for my B: drive does not come on)
I have just one image on the SD card.
I also tried it with and without termination on the floppy.
Do I need to change the defaults in the emulator settings? I have tried it with "2 Drives Emulation" switched OFF.
I have a twisted cable. Does that have any bearing on things?
thanks!
Hails
Jeff wrote:Set ID0-A on the floppy emulator, and set the drive jumpers as the second drive.
namachari
Post by namachari »
"I have a twisted cable. Does that have any bearing on things? "
Yes, possibly. Try both on a cable without the twist.
P
