Trying to Write Kryoflux Raw File
toml_12953
Post by toml_12953 »
I'm trying to convert .dsk and .dmk disk images to Kryoflux RAW format using HxC then use WildeWutz to write the raw files to a physical floppy. HxC creates a separate file for each track and WildeWutz never seems to be able to write anything to the floppy. Has anyone here used this combination to write real floppies?
Tom L
Re: Trying to Write Kryoflux Raw File
you should directly use dtc to do this job.
