Does anyone have a working config file for setting up a Korg 01/W with a Gotek HXC in Indexed mode [no lcd screen, just the 3 numbers on the front].
It supposed to be Dos 720k but like the Roland W30 etc, it uses this as a base then adds it own sector format on top.
Chris.
Korg 01/W config for Gotek HXC
Re: Korg 01/W config for Gotek HXC
have you any images ?chrispoacher wrote:Hi,
Chris.
chrispoacher
HI Jeff,
I've attached an image file.
- 01W-DISKIMAGE-OMNIFLOP-XDS-00P.zip
- Korg 01/W Omniflop image file.
- (197.73 KiB) Downloaded 808 times
chrispoacher
I think the disk image format is 80/2/9 x 512 720k.
To be sure can you use the hxc software to dump one of these disk to hfe ?
chrispoacher
It converts ok, file is too big to upload tho.
What do you mean by "It converts ok" ?chrispoacher wrote:It converts ok, file is too big to upload tho.
Send me them by emails.
chrispoacher
I meant I tried to upload here but the file was too big. Just sent to your email now.
