W30 system disk and sound disk
mikkmuzik
Post by mikkmuzik »
Hi Is it possible to have the sound disk for samples on the sd card for the system boot disk?
Re: W30 system disk and sound disk
mikkmuzik wrote:Hi Is it possible to have the sound disk for samples on the sd card for the system boot disk?
you mean the system boot disk with sounds ?
mikkmuzik
Post by mikkmuzik »
Hi Yes to save my samples on the same sd card as the boot disk sd card
teevee
Post by teevee »
Hi mikkmuzik,
your question seems a bit unclear.
You can have both your “boot disk image” and other “disk images incl samples/work” on the same SD card, if this is what you meant.
