Flashing Gotek
timbo81
Flashing Gotek
Post by timbo81 »
Good afternoon,
I have managed to install the drivers for my USB to TTL connector in Windows 10, however when flashing the firmware it gets to 48/100 and Windows 10 crashed to BSOD.
Can anyone please offer a suggestion of what to try in order to get this to work?
Thank you
teevee
Re: Flashing Gotek
Post by teevee »
timbo81 wrote:Good afternoon,
Thank you
1. Are you connected with Wifi or wired? (I would recommend wired)
2. Do you have the newest TTL driver for your device? (http://www.ftdichip.com/Drivers/D2XX.htm) (Note: I dont know if Windows 10 is supported)
3. Do you get any kind of error message on the booter program while flashing the firmware?
Re: Flashing Gotek
