Feature request: Disk2FDI FDI Format Support
firefly
Post by firefly »
Please can you add Disk2FDI image support.
Disk2FDI is a dos utility and a little hardware modification to read raw disk information.
http://www.oldskool.org/disk2fdi
The RAW track format FDI v2
Disk2FDI version 2 fileformat specification is here http://www.oldskool.org/disk2fdi/files/FDISPEC.pdf
A few emulators support the raw image format there are hardly any utils to convert between formats.
It would be useful if I can convert a FDI image to a RAW Kryoflux image format and visa versa if possible.
Thanks.
Re: Feature request: Disk2FDI FDI Format Support
Do you have some files to test ?
firefly
Post by firefly »
Yes, I have a few FDI containing different formats and still have the machine setup I used to create them.
firefly wrote:Yes, I have a few FDI containing different formats and still have the machine setup I used to create them.
Can you share some of them?
firefly
Post by firefly »
It took me a while but I have compile a selection of the different types for FDI images I have. These store a selection of FM, MFM and GCR formats.
Here is a google drive link to an arhcive of these FDI disk images and log files.
https://drive.google.com/file/d/0B6KL2m ... sp=sharing
