sixty_cel
Posts: 60 Joined: Sun Nov 22, 2009 3:29 pm
Post
by sixty_cel » Sun Nov 22, 2009 3:45 pm
Hi Every body
I made Stand Alone version But first problem after operate
no have massage on my display please someone help me.
emrez
Posts: 17 Joined: Sun May 20, 2007 1:50 pm
Post
by emrez » Sun Nov 22, 2009 5:01 pm
LCD pin 3. connected to the 10k ?
Did You install the bootloader and upd ?
What is the status rd3 led.
Regards.
sixty_cel
Post
by sixty_cel » Sun Nov 22, 2009 6:44 pm
The resault is
-Led 3 is blink blink 1 time and 3 seconds pause cycle
Why no have massage in LCD if I'm not choose SD inti the slot.
emrez
Post
by emrez » Sun Nov 22, 2009 7:08 pm
* Copy the new firmware file (HXCFE*.upd) to a freshly formated FAT32 SDCard.
* Insert the SDCard into the emulator
* Press Up and Down buttons before power up and keep it pressed at least 1 seconds at power up.
* Wait some seconds .... its done !
-- the lcd does not display in the firmware upd
information you can not do, I sends full hex.
Making (step by step video) coming soon
Best regards.
sixty_cel
Post
by sixty_cel » Sun Nov 22, 2009 10:12 pm
emrez
Thank you so much for compile file.
Now I an see letter in LCD YEH YEH YEH.
sixty_cel
Post
by sixty_cel » Tue Nov 24, 2009 5:08 pm
Hi Jeff
I'm try for several time.
the resault
-insert sd-card
-push up and down switch
-open power supply
-Led 3 Blink 4 times and pause 3 second
Regards
Posts: 8311 Joined: Fri Oct 20, 2006 12:12 am
Post
by Jeff » Tue Nov 24, 2009 5:17 pm
sixty_cel wrote: Hi Jeff
the resault
-insert sd-card
-open power supply
Regards
reflash your pic with the latest bootstrap, and use a freshly formated sdcard.
sixty_cel
Post
by sixty_cel » Tue Nov 24, 2009 5:19 pm
In Sd-card version in one-page of LCD can only have 1 file that convert from raw file .
Am I right under stand?
MS-Dos bootable is an hiden file how to fill in sd-card.
Regards
My Name Bird
sixty_cel
Post
by sixty_cel » Tue Nov 24, 2009 5:25 pm
If I want to fill more than one file in to one page of SD-card Can I do this condition?
The memory in usb type is 32 K/B.
Can I add the size of ram.
Or why the file is .hfe?
Regards
Bird
sixty_cel
Post
by sixty_cel » Wed Nov 25, 2009 12:53 am
Hi Jeff
Now I can operate the board.
i connect to PC but some file windows mesage
-the disk not format
-or some file please insert disk into drive a:
I think some mistake about raw file format configuration page
how to set config to test with pc.
regards
Post
by Jeff » Wed Nov 25, 2009 12:55 am
regards
what do you want test ? an *.img file ? or an new floppy image ?
don't forget to put a jumper in the right position.
sixty_cel
Post
by sixty_cel » Wed Nov 25, 2009 2:57 am
Hi Jeff
Now I can operate EMU all condition .
I think It is a wonderful project.
If I want to product to sell how I do.
Only in my country.
Jman
Posts: 16 Joined: Mon Feb 15, 2010 6:19 am
Post
by Jman » Mon Feb 22, 2010 2:52 am
I had same problem... thought my LCD was incompatible (TOPWAY LMB162ABC) but then I found the backlight pot.
In the words of Homer Simpson... DOH!
