DFL
Posts: 44 Joined: Wed Mar 18, 2009 1:56 pm
Post
by DFL » Tue Jun 16, 2009 11:28 pm
Since v1.2.0.11 the software supports D64 format.
So, can I replace the drive inside the 1541 unit by a stand alone emulator?
Is this working?
Posts: 8326 Joined: Fri Oct 20, 2006 12:12 am
Post
by Jeff » Wed Jun 17, 2009 9:39 pm
DFL wrote: Since v1.2.0.11 the software supports D64 format.
Is this working?
the c64 need the variable bitrate support. so for now the usb floppy emulator is the only one which could in theory support the c64.
But since i have never tested the D64 support on a real 1541/C64, you can consider it as non working. (that's why it is in an experimental state).
CrazyIcecap
Posts: 43 Joined: Wed Sep 24, 2008 2:38 pm
Post
by CrazyIcecap » Thu Jun 18, 2009 4:35 am
It could only replace the 1581, because the 1541 is a totally different system.
Post
by Jeff » Thu Jun 18, 2009 9:19 pm
CrazyIcecap wrote: It could only replace the 1581, because the 1541 is a totally different system.
the 1541 should be "supported" too, if you solder some wires directly to its motherboard
CrazyIcecap
Post
by CrazyIcecap » Fri Jun 19, 2009 8:35 pm
Tell me more....which wires do i have to solder to the 1541-board? Would be very interesting...
test29
Posts: 5 Joined: Tue Sep 29, 2009 9:00 am
Post
by test29 » Tue Sep 29, 2009 9:08 am
I am also interested in c64 and drives 1541 and 1581.
Does latest software for HxC usb version support d81 files for 1581.
Also does anybody knows how to connect 1541 to HxC, what wires do I need to solder and where?
Post
by Jeff » Tue Oct 06, 2009 7:14 am
test29 wrote: I am also interested in c64 and drives 1541 and 1581.
not yet. i don't have 1541 and c64.
CrazyIcecap
Post
by CrazyIcecap » Tue Oct 06, 2009 3:47 pm
need one? I have about 5 C64 and at least 3 1541-II...
