BAD FILE!
freshworks
BAD FILE!
Post by freshworks »
When i connect the standalone it now works and boots up the display and i can choose a ADF file.
When i select a file, it fast blinks 1 time BAD FILE!
Any suggestions ?
Cheers,
Jasper
freshworks
Anyone had the same issue ?
Cheers,
Jasper
freshworks wrote:Anyone had the same issue ?
Cheers,
Jasper
use this software to convert your adf file to the hfe file format :
and copy the hfe file to the sdcard.
freshworks
Jeff,
Is this a must ?
Thanks for time and replying,
Jasper
freshworks wrote:Jeff,
Is this a must ?
Jasper
yes
freshworks
Last question for the moment:
Can i do this by batch ADF2HFE ?
grtz,
Jasper
freshworks
Allready seen img2hfe, works fine batching.
Jasper
