Can somebody please tell me how to program with PICKIT2
freshworks
Post by freshworks »
i've bought a PICKIT2 but how do i connect the right wiress to the PCB, i know the 10 JACK will do, but it's seems i'am getting a error continuesly.
The PICKIT2 had the following pins:
1= VPP
2 = VDD
3 = VSS
4 = PGD
5 = PGC
6 = AUXILIARY ???
Where to connect these pins on the PCB (standalone SD version) ?
Do i need to put the board on 5 volt as well ?
Thanks, becoming really despered at the moment.
Cheers,
Jasper
error's within MLAB:
Initializing PICkit 2 version 0.0.3.30
Found PICkit 2 - Operating System Version 118.90.90
PK2Error0008: Read failure (GetLastError = Overlappende I/O-bewerking wordt uitgevoerd.)
PICkit 2 Ready
Reading Target
Reading Program Memory
PK2Error0006: Failed external call (Component = IHardwareMemory, Method = Synch, HRESULT = E_FAIL)
PICkit 2 Ready
Programming Target (20-5-2009 13:56:53)
Erasing Target
Programming Program Memory (0x0 - 0x61FF)
Verifying Program Memory (0x0 - 0x61FF)
PICkit 2 Ready
Re: Can somebody please tell me how to program with PICKIT2
freshworks wrote:Hi,
1= VPP
2 = VDD
3 = VSS
4 = PGD
5 = PGC
6 = AUXILIARY ???
Cheers,
Jasper
PICkit 2 Ready
Reading Target
PICkit 2 Ready
Erasing Target
PICkit 2 Ready
1= VPP -> J5 pin 2 (VPP)
2 = VDD -> J5 pin 4 (+5V)
3 = VSS -> J5 pin 1 (gnd)
4 = PGD -> J5 pin 7 (PGD)
5 = PGC -> J5 pin 8 (PGC)
6 = AUXILIARY ??? -> NC
yes. plug the pickit2 to the board, plug the board power supply, program the pic, unplug the board power supply, and unplug the pickit2.
your error messages seems very strange. are you sure that your pickit2 kit is well installed ?
freshworks
Hi jeff,
I think i have a circuit error, when i put the cable on the JACK the power led on the board is burning, when i turn on the power of the board and put out the pickit cable, the led is not lightening but will get power (multimeter)
Can this problem be a capacitor problem
i've used 35 volts and for the 10uf 63 volts
Also with the jack in, i get NO DEVICE DETECTED :cry:
Probaly i need to redo the whole board .........
Cheers,
Jasper
freshworks
OK, boardproblem fixed so far, i've got power now, ground issue.
now the only thing i have is that i can't program the PIC18F4620
The pickkit2 software says that no device is connected, pickit2 is connected, it can't find the PIC18F4620.
I did what you tolded me Jeff,
1. connect the board
2. connect the pickit2
3. write hex file (device not detected)
Is there another way with the pickit2 to write the hexfile in the PIC18F4620, probaly with a simple PCB or something ?
Please help me, last issue to do for a working device probaly ?
Cheers and lots of thanks,
Jasper
freshworks
Made a PCB with 10uf capacitors between VSS and VDD on both sides. After this it works and managed to program the 18F4620
