SD Card Version alternative components
freshworks
Post by freshworks »
I've been searching together all the components on different websites, but some are still missing.
Are there alternatives for the following components :
- Y1 10Mhz CRYSTAL UNIT (have to pay 25 euro because of USA stock farnelll)
==> WILL THIS FITT: http://www.voti.nl/winkel/catalog.html?X-10M
- J1 EMBASE ALIM 2.1MM (cause of orderunit is minimal 10)
- J3 HE10 header (Website does not find the component anymore ?)
http://www.selectronic.fr/article.asp?a ... .0425-9999
U6,U8 74LS01 Quadruple 2-input Positive NAND Gates with Open Collector Outputs
http://www.selectronic.fr/article.asp?a ... .4352-9999
- Anyone knows a place where to get the PIC18F4525 or alternatives witch will also work porperly.
=> FOUND THIS IN MY COUNTRY (NL): http://www.voti.nl/winkel/catalog.html?pics
Thanks and keep up the nice project.
Jasper
trungvn
Post by trungvn »
quote: "- Anyone knows a place where to get the PIC18F4525 or alternatives witch will also work porperly.
=> FOUND THIS IN MY COUNTRY (NL): http://www.voti.nl/winkel/catalog.html?pics"
- you can buy the PIC18F4525 on ebay or you use PIC18F4620 instead of PIC18F4525.
as trungvn said, you can use the PIC18F4620.
this should.
freshworks
Thanks Jeff
CrazyIcecap
Post by CrazyIcecap »
What about the Display? Is it HD44780-compatible?
CrazyIcecap wrote:What about the Display? Is it HD44780-compatible?
yes any HD44780 compatible lcd should works.
elvvn
Hi!
Post by elvvn »
trungvn wrote:quote: "- Anyone knows a place where to get the PIC18F4525 or alternatives witch will also work porperly.
Hi Trung,
I am in Vietnam. I don't know where can I buy PIC18F4525 or PIC18F4620?
elvvn@yahoo.com
