Two DF0:'s, one at a time.
chapas
Post by chapas »
can i add a switch/s to the cable/s to have one drive working and the other completely turned off and when i wish, switch (with Amiga turned off) to the other drive.
Regards,
Chapas
Re: Two DF0:'s, one at a time.
Yes a switch on the DS0 (10) wire can be added to selected the drives.
chapas
Post by chapas »
Thanks, that is enough? I was also thinking on motor enable.
