Converting DSS-1 Omniflop images to HFE
k-Tracker
Post by k-Tracker »
please, help I stuck with DSS-1.
I have successfully converted all *.dss library since it was automatically recognized by HxC software, but can't convert my Omniflop library in *.IMG format.
I did following:
1. downloaded custom layout file posted here: empty_korgdss1.fpf
2. in the Load RAW Image menu selected "Custom Layout", loaded fpf file and then Loaded RAW file (*.IMG)
3. plug into DSS-1 and it reports it as unformatted.
Please, help. I attached IMG file and FPF file I used.
la.part2.rar
(220 KiB) Downloaded 3248 times
la.part1.rar
(220 KiB) Downloaded 3264 times
empty_korgdss1.zip
(172 Bytes) Downloaded 3120 times
k-Tracker
Re: Converting DSS-1 Omniflop images to HFE
Post by k-Tracker »
3rd attachment is here
la.part3.rar
(94.96 KiB) Downloaded 3194 times
General rule : Please avoid omniflop -> It just output raw/dsk file and doesn't give any detail about the disk geometry... Use the HxC dump tool instead or ImageDisk which use a better file image format (*.IMD).
the fdp file seems to be corrupted.
Anyway i will add the one xml description into the layout format list for the korg.
k-Tracker
Post by k-Tracker »
Thank you Jeff, noted.
Can you let me know manual settings so I should not wait until XML info is added into the tool?
k-Tracker
Post by k-Tracker »
Awesome, thank you!
