Suggestion
DFL
Suggestion
Post by DFL »
How about an option to convert a HFE file into an "real" image again?
That will be useful when we write a program or something in SD and need to put in a real disk.
Is this possible?
Regards.
Pryanick
HFE2IMG
Post by Pryanick »
It would be very useful to convert img2hfe and vise versa.
I think that first found on SD card image automounting would be useful too.
ZX-Spectrum/128k/TR-DOS/HxC Floppy Drive Emulator/YM2149F/ROM-DISK
Re: Suggestion
DFL wrote:How about an option to convert a HFE file into an "real" image again?
Is this possible?
Regards.
Yes this is possible, and i will add it soon.
Re: HFE2IMG
Pryanick wrote:It would be very useful to convert img2hfe and vise versa.
yes this will be done soon.
trungvn
Re: HFE2IMG
Post by trungvn »
I think if this emulator can read and write img file instead of hfe file, we don't need to write a program to converthfe2img and there are many freeware supported the img file.
Re: HFE2IMG
This means that the PIC must encode data sector in real time. hard to make something cycle accurate.
This also means that the PIC must be able to read all file image format : *.ST/*.MSA/*.STX/*.ADF/*.ADZ/*.DMS/*.IPF/*.DSK/*.IMG/*.TRD/*.SCL/... All these files formats are quite different, and need a specific loader. And some of them are quite impossible to "read" with a simple uC (memory and speed problems, example : gzipped file format image like ADZ).
Additionally the conversion program allows me to easily change the hardware (change of the PIC by an other uC or a FPGA) without rewriting all of the project…
Remember : the HxC Floppy Emulator is mainly a software project, not a hardware project ;-)
So no, the PIC board will never directly read/write IMG file format.
Pryanick
Post by Pryanick »
Lets work with hfe-file but not with real img-file, its much more easier.
So hfe2img converting program would be usefull :)
Pryanick wrote:Lets work with hfe-file but not with real img-file, its much more easier.
done : https://hxc2001.com/floppy_drive_emulat ... r_soft.zip
you can extract all floppy sector to a img file (rename it to trd to have a trd file :wink: )
Pryanick
Post by Pryanick »
Hi Jeff
I have tested new program version.
Its working!!!
Image hfe-file changed by Spectrum under HxC emulator I can convert into real *.TRD image file.
TnX, Jeff!
:D
DFL
Post by DFL »
Pryanick wrote:Hi Jeff
Its working!!!
TnX, Jeff!
:D
Works for me too (TRD in Spectrum and DSK in MSX)...
Thanks Jeff
DFL
Post by DFL »
Its working!!!
TnX, Jeff!
:D
Thanks Jeff
ADF doesn't work. Crash the program. Tried with many images...
Its working!!!
TnX, Jeff!
:D
Thanks Jeff
normal, it's not supported at this day -> amiga format is not the ISO standard.
DFL
Post by DFL »
Jeff wrote: normal, it's not supported at this day -> amiga format is not the ISO standard.
Hey Jeff,
any chance to see an HFE->ADF support soon?
Thanks.
Hey Jeff,
Thanks.
why ? the standalone version is read only for the amiga. So it seems useless to me to have an hfe->adf file converter ?
DFL
Post by DFL »
Hey Jeff,
Thanks.
Hmm... I forgot about that. :oops:
So... Any chance to see ADF with write support? :lol:
