trouble with HP 16500A
nebelfuerst
Post by nebelfuerst »
I bought Rev C to get a replacement for the HP16500A logic analysis mainframe.
The disk seems to be DD. Unfortunately the .hfe is not reported to be "unknown format".
I'm using the PCB posted on this board to adapt the HP-floppyplug to the HxC.
( I also checked most of the lines with a scope, so the pinout seems to fit.)
Anyone has allready tried to emulate the HP16500A with its strange LIF disks ?
What should I try ?
( I tried to attach my .hfe, but file is 2Mb, which cannot be attached in this forum ?)
Re: trouble with HP 16500A
Have you a working disk for the HP16500A ?
nebelfuerst
Jeff wrote:Have you a working disk for the HP16500A ?
Sorry for late reply, I was on a short vacation...
Yes, I have a working disk for the HP16500. I was also able to read it with the software.
(Within the disk viewer, I can seen text-fragments, that seem reasonable to me..)
The drive to replace on HP16500 is a Sony MP-F52W-30.
As this drive has a different pinout, I use my vintage PC-Floppy to read the disk.
Isn't a 600 RPM drive ? Can you share the HFE file ?
nebelfuerst
Jeff wrote:Isn't a 600 RPM drive ? Can you share the HFE file ?
Yes, drive is 600RPM. ( I just checked with my measuring device for model planes :wink: )
I tried to attach the file, but the HFE is too large, even zipped.
How can I share ?
How can I share ?
nebelfuerst
I'm still stuck.
When attaching the drive to the 16500, I can see the trackcounter move to 1 , then to 80.
But then it runs up to 160/80 ..
I suspected my adapter-PCB to be faulty, so I built a second one with the same result.
What can be the cause of my trackcounter walking beyond the maximum ?
check the dir and step signals.
nebelfuerst
Jeff wrote:check the dir and step signals.
Oooops :roll:
Looks like i mirrored the pins, so 2 ends up at 34 ...
I used a PCB from this forum without thinking too much . :shock:
I'll do a new PCB next week to fix this ..
I'll be back :mrgreen:
nebelfuerst
got my PCB correct. ( Those HP-guys just inverted the red line of the wire, just to confuse me.)
I was able to fix the "endless increasing track problem":
The TRK00-line remained low, thus indicating the head didn't move forward.
As the HxC uses a OC-Output, I had to clue a pullup of 10k to it to make it work.
( the original floppy is able to generate high, although there doesn't seem to be a common pullup.)
As my HxC now seems to move correctly ( include side) and I'm still not able to read from it, I'd like to know:
- Are there more lines that should get a pullup ?
nebelfuerst wrote:got my PCB correct. ( Those HP-guys just inverted the red line of the wire, just to confuse me.)
Yes : at least the RD line. The Slim schematic is available there :
https://hxc2001.com/download/floppy_dri ... Design.zip
nebelfuerst
with all OC-outputs fitted with pullups of 1k, the signals look good now. :D
The steering write/tracks seems to work, but the data isn't understood yet.
The RD-line on the 16500a shows a baudrate of 250kHz, even if no floppy is acting... this is sent by HxC is this normal ?
When the other internal floppy is active, I can see 500kHz pulses.
I tried to change baudrate and rpm of the HFE with trackeditor-> set rpm/set bitrate.
But this doesn't seem to work.
How to change the rate/rpm ?
nebelfuerst
I made it !! :D :D :D
Using this image from this thread:
viewtopic.php?f=25&t=1296
I got a disk, which my 16500a was able to diskcopy the system disk onto.
Now I'll rework my PCB with the pullups to become a enduring solution.
Just curious:
Where can I read how to set the rpm/bitrate of an existing image ?
( I pressed "set ...", but it didn't work...)
nebelfuerst wrote: Where can I read how to set the rpm/bitrate of an existing image ?
Into the track viewer -> edit tool.
Btw would be nice to share this system disk image.
nebelfuerst
I'll try this rpm/bitrate setting again next week. It didn't work for me yet..
I sent you the bootable .hfe and .cfg per mail.
( I tried 509kB, but the limit ist 256KB. So i splitted into two files, but the extension .001 was not allowed... What is the elegant way to bring 509kB to this board ?)
