Hi, I need OS Emu Emax HD and the instructions to download the SD card, because the OS emu emax SE fails, it appears in the display sampler "wrong program" I have SD floppy emulator Rev. F
I await your response to begin copying images of sounds on the SD card.
Regards!
Help! OS Emu Emax HD and instructions to copy to SD card
CharlyFlopEnsoniq
Re: Help! OS Emu Emax HD and instructions to copy to SD card
Have you the OS floppy disk ?
CharlyFlopEnsoniq
Thanks, I solved with the batch converter, put it in a folder the OS and sound banks EM1, converting all I can next load the operating system on each sound bank, sometimes a message appears on the display of the sampler that says " insert disk ", back to try and load every sound bank. For now everything is working OK.
Thanks and regards!
Thanks and regards!
