Which Gotek version for casio FZ1
the fuze
Post by the fuze »
I want to change the FZ1 Floppy with an Emulator. Anyone with a working device in a Casio FZ1.
can someone explain the difference between the Gotek Versions
- SFR1M44-U100
- SFR1M44-U100K
- 3.5" USB SSD Floppy Disk Drive Emulator 144 MB HN
Or is the Hardware the same and it depends on the Firmware? The above Version U100K seems to be functional for my FZ1 because of the info 1,44MB 2HD the FZ1 uses. But the info (SFR1M44-U100K not support jumpers) scares me.
I found the following description in the bay:
This floppy drive emulator is great for industrial control equipment. It has the same size as the ordinary 3.5" floppy drive, same mounting hole locations and floppy drive.
Description:
100% Brand new, never used
Housing Material: ABS
Color: Black
Model: SFR1M44-U100K
Use normal USB flash drive as the medium for transfer design.
34pin floppy driver interface, 5V DC power supply, easy to install.
Capacity: 1.44MB 2HD Cylinders: 80 Tracks: 160 Sectors/Track: 18 Bytes/Sector: 512 Data
Transfer rate: 500 kbps Encoding method: MFM.
1000pcs partitions in USB flash drive can be used.
Built-in self-format function. (read relevant documents to use this function)
Jumpers with function for different machines(SFR1M44-U100K not support jumpers).
Floppy driver with below function needed:
Floppy driver with 34pin interface,and 5V DC power plug
Use 2HD flpppy disk with 1.44MB capacity
Format of disk : Cylinders: 80 Tracks: 160 Sectors/Track: 18 Bytes/Sector: 512 Date
Suitable for industrial control equipment
Panel:
8 segment numbers: represent partitions number
Green led: status of read and write operation
USB port: connect USB flash drive
Button:
Left button used to rise ten-digit, right botton used to rise single-digit
Press 2 button together to rise hundred-digit
Operation :
Format USB flash drive
Use built-in self-format function to format USB flash drive into 1000pcs
partitions.
Use software in CD format USB flash drive under WINDOWS XP/2000, into 000-099
100pcs partitions.
Install an emulator on computer, and format every partitions by operate
driver A:.
use emulator UFA1M44-100, plug USB flash drive on it,connect to computer, it
will recognized as removabe driver A: or B: under WINDOWS XP/2000/7, format
every partitions.
UFA1M44-100 also built in self-format function.
Read and write data.
Install emulator on machine
Install emulator on computer
Connect USB flash drive on computer, read and write data directory by
software, under WINDOWS XP/2000
Use emulator UFA1M44-100, plug usb flash drive on it, connect to computer,
read and write data under WINDOWS XP/2000/7
Jumper setting:
J5:---
JA:---
JC:---
JB:---
S0:Driver select 0
S1:Driver select 1
MO:Motor
Compatible with:
YAMAHA/KORG/a majority of ROLAND(except Roland E-66, E-86, E-96, G-600, G-800, E-480B, E600) electronic organ, etc
Package Includes:
1 x USB Emulator
1 x CD
4 x Screws
Or is a SD-Card version a better solution?
Any help would be great, to get my FZ1 runnin´again.
Kind regards
agent29
Re: Which Gotek version for casio FZ1
Post by agent29 »
Hi I am running the SFR1M44 Gotek in a FZ-10m (rackmount FZ-1) which has been flashed with the latest HXC FW. I had few issues to start with but it was FW related.
The differences in revisions I believe relate just to their stock FW's. There is very little or no difference in the hardware unless you have the SFR72 type drive with two digit display, I have one of these also and it works in the FZ aswell.
If its a brand new Gotek unit from any auction site you will need to get the bootloader and FW flashed anyway before fitting to the Casio so it shouldn't make any difference.
Yrouel
Post by Yrouel »
The SFR1M44-U100 and SFR1M44-U100K are identical besides the case color so I guess you should pick the black one to match the FZ-1.
BTW when looking for one of these emulators just search the words floppy emulator on ebay (or aliexpress) and look closely at the picture for the listing. You want one with a 3 digit display which indeed both the aforementioned models have.
