Just getting started.. Questions.
dabone
Post by dabone »
Ok, I've got a gotek with the hxc firmware loaded and working on a Amstrad PPC640.
It's working fine in indexed mode.
My questions are about the DOS Disk browser.
1. Is there a version of this for 720k users?
2. What is the CPU/Ram requirements of this software? (I'm running a 8088 with 640k)
3. If it will work on 8088 machines, where are guides/tutorials on the larger floppy disk formats?
Thanks.
Later,
dabone
Re: Just getting started.. Questions.
You mean the file selector or the dos disk browser ? I don't understand.
dabone
Post by dabone »
Ok, is there a utility to browse the disk images located on the card/usb from dos on the machine that the hxc is installed in.
I'm installing it in a floppy only system, so it would be the only drive located in the machine.
Thanks.
Later,
dabone
dabone wrote:Ok, is there a utility to browse the disk images located on the card/usb from dos on the machine that the hxc is installed in.
Thanks.
Later,
dabone
Ok. there is a x86 version available
The .EXE can be downloaded there :
https://github.com/bjt42/hxcfs
