HxC on MSX
Dioniso
HxC on MSX
Post by Dioniso »
Hi!
I have just bought one HxC :D
I have installed the CDM 2.04.16.exe (drivers) on Windows XP, run the Software on PC, put a DSK image, got the cable from the disk interface of my Philips 8245 MSX2 (720k), plugged it to the HxC, USB to HxC, turned on the MSX2 and... nothing.
Any idea? Have I read there is some kind of incompatibility?...
Dioniso
Re: HxC on MSX
Dioniso wrote:Hi!
Dioniso
mhh did you start the server software (https://hxc2001.com/floppy_drive_emulat ... r_soft.zip) ?
What is the behavior of the leds ?
Dioniso
Post by Dioniso »
Thanks, Jeff, for your answer.
Before running the PC software I have D1 on.
When running the PC software I have D1 on and D4 led blinking.
When I insert a DSK I have D1 and D4 on (80 Tracks, 9 Sectors, 2 Side (s), Track: 00/80).
When I turn the MSX2 on it reads quickly some of the lower tracks and then go to MSX BASIC directly.
Could that be because I have to change something on the cable? :?:
Dioniso wrote: Could that be because I have to change something on the cable? :?:
i don't think so. which file image are you using ?
D2 and D3 stay off?
Dioniso
Post by Dioniso »
I used a promo DSK from Arkanoah (MATRA). It's a 720k DSK image. I have tried 360k, too. Some other 720k games like SD SNATCHER, UNDEADLINE, etc...
Can you point me to an image you now for sure it works? It could be the format but it sounds really strange to me.
Dioniso wrote:I used a promo DSK from Arkanoah (MATRA). It's a 720k DSK image. I have tried 360k, too. Some other 720k games like SD SNATCHER, UNDEADLINE, etc...
D2 and D3 stay off during the msx boot?
Dioniso
Post by Dioniso »
No, sorry. When booting, and the MSX beeps, the blink once.
Dioniso wrote:No, sorry. When booting, and the MSX beeps, the blink once.
If the msx try to access the floppy drive, D2 should be on.
During head stepping D3 should blink.
If these leds stays off, try to change the drive select source in the Settings menu (DS0,DS1,DS2,..).
Dioniso
Post by Dioniso »
When DS0 or DS2 selected, D2 led doesn't turn on.
When DS1 or MTRON selected, D2 led is on while trying to get access to the disk... but it goes to BASIC everytime.
By default, the software recognizes that I'm working with a MSX image.
Dioniso wrote:When DS0 or DS2 selected, D2 led doesn't turn on.
mhh this strange. the msx boot only on ds0 ?
where have you plugged the floppy emulator ?
can you try to list the second drive content with the basic ?
can you send me an image to this email :
https://hxc2001.com/contactus/hxc_email.jpg
is this your msx ?:
http://msx.retro8bits.com/msxdocs/philipsnms8245sm.pdf
did you do this?:
http://www.msxarchive.nl/pub/msx/mirror ... s8245e.pdf
Dioniso
Post by Dioniso »
I have just sent you an email with pictures, info, etc.
The model I am testing is a NMS8245 with a PC diskdrive, so the connector is already a 34 pins one.
I will try on a NMS8280 right now.
hmm there are a problem with this dsk : there are no data in ArkPromo.dsk
!!!! (full of 0 -> you can see this with an hex editor )
this can explain with the msx doesn't see it...
can you retry the floppy emulator set on DS1 on the NMS8245 with a good floppy image (tested with an msx emulator for example).
Dioniso
Post by Dioniso »
Jeff, thank you very much!!!
As I told you, I had already tried several DSK images, but always with DS0. And the other test (DS0, DS1, DS2, ...) I did them with that false DSK image :oops:
Now it works!!! Thanks!!! I had to use the DS1.
As for the 8280, I just checked plugging the HxC on the second floppy unit and it didn't work. Do you want me to try it on the first diskdrive? I have several models, if you want me to try the HxC (but I guess it should work on every 34pins model).
-SONY HB-F1XDmk2 (Japanese MSX2)
-PANASONIC FS-A1S (Japanese MSX2)
-SANYO PHC-70FD (Japanese MSX2+)
-PANASONIC FSA1-ST (Japanese MSX Turbo-r)
Again, thank you very much. Very useful hardware! You can check my games here: http://msxdev.msxblue.com/ (under Dioniso)
A free MSX emulator very very accurate, here: http://www.bluemsx.com/
Merci pour m'aider et a+,
Dioniso
Dioniso wrote:Jeff, thank you very much!!!
Dioniso
Good ! :)
Yes you can test it with all configurations (DS0,DS1,DS2...). The good configuration is depending of the computer, the floppy cable and the floppy disk drive type (PC, Shuggart,... ) supported by the computer.
